Preset Radio Stations
I have a 1998.5 A4 and don't have an owners manual. I have two questions related to the radio:
1.) Can someone please explain how I program radio stations? 2.) Is there anything I should know about the radio before I replace the battery? Your feedback is appreciated. Shawn |
RE: Preset Radio Stations
Be sure if you have the bose system that you have the radio code before unhookin the battery....... and all you have to do to set the stations on mine is go to the station and press and hols the button you want it to be
Same advice as above but all radios have a code that you need to know before disconnting the radio, not just the bose. Holding the preset that you wish to program should set the current radio station to that preset. You will hear either the sound cut out or a beep. If neither happens yoo have a problem with the radio.
Thanks very much to you both.
