Quattro fuel filter replacement
Old Feb 1, 2008 | 03:28 PM
manufan's Avatar
Default Quattro fuel filter replacement
Let me start by saying what a pita this is to change. Why Audi placed it in the way they did escapes me. I read a few DIY before I got started and one was very helpful. The filter is held by a plastic ring that is pinched together with a triple square which I don't have. Even if I did, you can't get to it. Simplier way, take off the bottom banjo fitting, cap the filter with the cap that comes on the new filterso it doesn't drip on you. Grab the filter with giant h2o pump pliers and pull it down out of the holder. You have to pry the plastic ring that keeps it from sliding down out of the way, once that's out of the way it comes right out. If I did it again, I don't think I would even lower the tank at all. Funny thing, I think the filter was original, 175k on the car.
Old Feb 1, 2008 | 03:33 PM
techbod's Avatar
Default RE: Quattro fuel filter replacement
been there[:@]
Old Feb 1, 2008 | 03:56 PM
dankhound's Avatar
done that[:@]
Old Feb 1, 2008 | 04:02 PM
tealetm's Avatar
must be completely different on the B6 because mine literally took me 10 minutes to do.
Old Feb 1, 2008 | 04:58 PM
Papachristou's Avatar
i had trouble with the little bitch plastic connectors on the b6.. just a matter of knowing the trick
Old Feb 1, 2008 | 06:46 PM
Trey25's Avatar
Yea it is a PITA. Why it was placed there is beyond me. The hex/torx bolt for the strap was rusted and stripped so I just cut the strap and pulled out the filter.
Old Feb 1, 2008 | 09:26 PM
auditech79's Avatar
B5 fuel filter =5 on the difficulty scale.
B6 fuel filter = 1 on the difficulty scale.
Old Feb 2, 2008 | 05:43 AM
feerocknok's Avatar
B5, 20 min, first time. Jack up the car, loosen the straps, pry, insert 2x4, release torx, undo fittings, remove filter, reverse operation. Where are you guys having issues?
Old Feb 2, 2008 | 08:17 AM
TorsenTaxi's Avatar
Issues were "salted winter roads" and banjo oxidation. Physically replacing the filter was a slight pita, but the small pits in the surface of the lower banjo fitting required patience, filing, and polishing before it was leak free was the major pita. Evenafter multiple new copper washers (one at a time and one time only), it had a drop of gasevery 5 seconds or so until the banjo fitting face was resurfaced.
Old Feb 2, 2008 | 02:57 PM
wood_e's Avatar
Yeah - total PITA
