question about light
Old Jun 28, 2007 | 09:55 AM
samoht's Avatar
Default question about light
I have a 2003 audi a4. On my LED display, there is a warning light (similar to where the gas warning shows up) that has a circle and then another circle in the form of a dotted line around the inner circle. It looks like a tire to me, so I'm thinking that the tire pressure is low, but I just wanted to check with the experts here first, since I don't have an owner's manual . If it is indeed the tires being low, how much should I fill them?
Thanks so much!
-Thomas
Old Jun 28, 2007 | 10:09 AM
CRAZYHAWK's Avatar
Default RE: question about light
(O) Add brake fluid.
It could also mean the front brake pads are worn.
Old Jun 28, 2007 | 11:44 AM
tjolson19's Avatar
Yea, that is for the front brake pads...There is a sensor in the pad and when it gets low it breaks, similar to when you hear brakes squeaking you get to the wear bar....Same thing, but there's a sensor instead of a wear bar
Old Jun 29, 2007 | 01:38 PM
samoht's Avatar
Thanks so much for the responses! This is very helpful. I went out and bought some brake fluid, and found the compartment in the car in which it goes. I took the first cap off and started pouring (into a filter-like thing). However, it didn't really go in, it just kind of spilled, so I stopped pouring. Is there a special way to put it in? Thanks.
Also, do I just need to add brake fluid, or do I need to take the old fluid out? Thanks!
Old Jun 29, 2007 | 07:24 PM
samoht's Avatar
Ok, the story develops a bit more. I showed it to a mechanic-type who knows what he's doing and he said the brake fluid was full. However, the brake pads are pretty new (~6 months), so I don't think it is that. More recently, the brake light started flickering (as well as the light I mentioned up above). Any ideas what could be going on? If not, I'll probably just take it to the mechanic.
Thanks!
Old Jun 29, 2007 | 07:34 PM
CRAZYHAWK's Avatar
The car should be level when adding brake fluid. Add slowly to the top.
v8_ranch
Aug 27, 2012 12:45 AM
numlock4045
Feb 9, 2011 07:12 AM
superdooperme
Oct 9, 2008 12:15 AM
beckmaster
Apr 13, 2008 08:39 AM
