Questions, Questions, and More Questions
So 1st question: My front left is squeaking... but if i push down and lift up on it a couple times (to find out where the squeaking is) it goes away. I've narrowed it down to somewhere underneath the car. What to replace? Can I just lube it up?
2nd question: My rear sway bar is squeaking as well. Lube just shuts it up for lil bit then it comes back. Its where the U joint holds the bushing and bar onto the car. I am thinking of replacing the sway bars with aftermarket instead of OE. Any reccomendations for a non-sport suspension?
3rd Question: I think my front left CV Joint Boot is leaking oil or something because its gooped to high hell. What does it cost to replace this?
4th Question (I told you I hard alot): If I reaplce my front bumper with an S4/RS4 or RS4 Lookalike what can I do to keep my existing headlight washers? Is this possible?
Do headlight washers interfere with a FMIC?
I think that is it for now....
My car is a sqeak monster right now, which is kinda annoying. I am thinking of doing this when I replace my rear wheel bearing.
