Radiator Coolant question
Pep Boys says i can use the orange coolant they have for i believe GM, is that OK?
RE: Radiator Coolant question
NO, it may cause the system to turn to gel.
It's not worth it to save $10. |
What do you recomend? would the regular green coolant do it or is there anything i can get at a local auto parts store?
Pentosin G12
Get it from one of our sponsors or the dealer. Its not found at pep boys or any other local store unless you have a euro tuning shop close by maybe. |
Thanks man, i will do some searching on that
Yes, either Petosin, VW, Audi & Porsche all use it.
It HAS, HAS to be G12, or G12+ All else will be BAD. You only need one gallon, and then at least 2 g of Distilled water. |
I just called my dad,he works for Mercedez-Benz and hes going to ask the parts dept. if they carry it, if they do ill pick some up after work, its about 7 blocks away.
ORIGINAL: southcoast I just called my dad, he works for Mercedez-Benz and hes going to ask the parts dept. if they carry it, if they do ill pick some up after work, its about 7 blocks away. It's orange, & they have like 4 types. http://www.mbca.org/pages/tech/MBCA_Antifreeze.htm Why are you fighting the system so bad here? YOU NEED G12, GO BUY G12, NOTHING ELSE! |
