Radio in Safe 11 mode
Old May 11, 2004 | 11:17 AM
robz's Avatar
Default Radio in Safe 11 mode
After disconnecting the battery, I inputted the radio code in the correct way but made a mistake on inputting the number. Now it is displaying 'SAFE' with II at the left hand side of the display. It now won't accept the code, even if I disconnect the battery again.
It's like it has remembered the mistake and won't allow any further operations
Can anyone help?
[&o]
Old May 11, 2004 | 01:20 PM
brrman's Avatar
Default RE: Radio in Safe 11 mode
SAFE II means you are on your second try for entering your radio code. You have to wait an hour I believe with the key out of the ignition before you can try again.
Old May 11, 2004 | 01:28 PM
robz's Avatar
Thanks, I'll try that.
Old May 11, 2004 | 06:12 PM
brrman's Avatar
Rob - srry I made a slight mistake...
heh
The radio must remain turned on and the key must remain in the ignition during that one hour period
Old May 11, 2004 | 08:03 PM
active1331's Avatar
if its under warrenty take it to the daeler they can reset the radio[:'(]
Old May 12, 2004 | 11:29 AM
robz's Avatar
It worked, ignition off and radio on for one our, it returns to safe mode. Thanks a lot
Old May 12, 2004 | 03:40 PM
brrman's Avatar
ah ok cool. I could not remember if ignition had to beon or off.
mickrimmer
May 3, 2014 08:49 AM
noubey27
May 27, 2011 09:03 AM
BMF!
Jan 27, 2009 05:25 PM
melrose man
Aug 29, 2007 08:41 PM
AudiGuy2.8
Jun 7, 2006 01:52 PM
