Radom Idle problems
Old Nov 17, 2006 | 03:56 PM
scotia4444's Avatar
Default Radom Idle problems
I have the 2.8 A4Q. I changed my oil yesterday after doing the sea foam in a vacuum hose (brake booster). Then after that I drove my car around letting the oil run through the car. I stoped at a red light and it droped down to around 50 RPM and shot back up to normal idle. I was woundering if anyone one knew what would cause this help would be thanked. I changed my oil today (next day) and it still does it. It has no codes. It also has a huge new oil filter (bigger than the one that was on the car before the first oil change). I added engough oil to compensate for the bigger filter.
Old Nov 17, 2006 | 04:03 PM
techbod's Avatar
Default RE: Radom Idle problems
oil filter has nothing to do with it, accelerate to 3k rpm and hold for 3 mins this should reset the ECU then take it for a drive
Old Nov 17, 2006 | 05:29 PM
sandnsnow24's Avatar
yep first resest ecu. if that doesn't fix it..... if it's an older 2.8 like mine is like a 96, then it could be the ICV, Idle Control Valve. When i bought mine it had a malfunctioning icv and the owner thought it was a big problem with the engine. It's not at all, all you have to do is clean it out with carb cleaner becaues gunk gets built up in it. Its a last resort though, cuase it take like 3 hours to do. Find the write up on it if you think it's your problem.
Old Nov 17, 2006 | 08:03 PM
acetrebo's Avatar
Drive 40 miles until the ecu resets completely.
Then see where its at.
Old Nov 17, 2006 | 09:05 PM
CRAZYHAWK's Avatar
You might need a throttle body adjustment.
Old Nov 17, 2006 | 10:26 PM
scotia4444's Avatar
thanks for all the help i will try all your ideas
Old Nov 18, 2006 | 06:55 PM
scotia4444's Avatar
I was thinking wouldnt reseting the ecu get rid of the misaligned headlight "code"
And my car doesnt do it anymore
Old Nov 18, 2006 | 07:04 PM
techbod's Avatar
eeeee these new cars get my head up my ar2e what will the add to the computer/ ECU to confuse us misaligned headlight "code" new one to me
audia4man
Apr 23, 2013 05:46 PM
twoeightquattro
Dec 19, 2010 12:09 PM
c346123
Apr 13, 2007 04:04 PM
robjay31
Sep 19, 2006 05:09 PM
96A4QuattroGuy
Sep 17, 2006 07:17 PM
