rear sway bar
Old Mar 12, 2005 | 04:35 AM
  #21
TexA4's Avatar
Default RE: rear sway bar
ORIGINAL: audihere
same as the rear. these sway bars dont snake through anything like most cars do. un bolt replce mounts an ur done
The front is considerably harder to install than the rear bar. There's a lot more to deal with up there (Engine, Rack and pinion, etc)
Old Mar 12, 2005 | 06:42 PM
  #22
audihere's Avatar
Banned
have u done it on a 1.8t? ive looked at it didnt see anything in the way.
Old Mar 12, 2005 | 07:20 PM
  #23
A4NightRider's Avatar
in interested to know what kind of difference the rear sway will make... im pretty sure i could bend and weld my own sway bar if given the specs as well....far cheaper and with better quality...
Old Mar 12, 2005 | 07:36 PM
  #24
CRAZYHAWK's Avatar
A stiffer rear sway bar will reduce understeer.
Old Mar 12, 2005 | 08:15 PM
  #25
hmm..i think i'll give it a try.......i'll take a look at my car...and see what i'll need....
Old Mar 12, 2005 | 08:16 PM
  #26
apg96's Avatar
look at this user review form AW
Neuspeed rear swaybar kit with subframe braces and all hardware and bushings.
The Neuspeed 19mm rear bar has been an excellent addition to my existing Bilstein Sport shocks/Eibach Pro-Kit lowering springs.
The rear bar has dramatically reduced the body roll under hard cornering. The rear end no longer "dips" when thrown into a hard curve. Highway stability also feels improved.
It is important that the supplied subframe braces are installed with the bar. I'm amazed how thin the subframe is where the stock swaybar attaches.
But will the car go from understeer to over steer if i only do the rear?
would get them from here even though it LLtek or is there somewhere else?
Old Mar 12, 2005 | 08:22 PM
  #27
well, if i do it (i know it'll be cheaper doing it myself), then i'll possibly do it for others for far cheaper....there is not 300 worth of work in them at all...
Old Mar 13, 2005 | 06:51 PM
  #28
apg96's Avatar
it wont make the ride stiffer will it?
Old Jul 18, 2005 | 09:37 PM
  #29
toaster's Avatar
i love more or less everything about my 02 a4, but i also am interested in antisway bars.
what would this alone do for me?
http://www.namotorsports.net/detail....d/NS25.02.21.4
do i need one for the front too?
thanks.
Old Jul 19, 2005 | 04:26 AM
  #30
apg96's Avatar
its makes it so u can take turns faster and make ur car seem like its on rails. U dont have to have the front. If u have the rear only u will get oversteer, and adding a front will keep it balancd liek it is now just with the ability to take turns faster. Its a great mod. It is gonna be my next one. And if u have sport u are less likely to need the front as supposed to needing it on a regualr suspension.
smittylube
Oct 17, 2013 10:34 PM
villacorta32
May 13, 2012 06:13 PM
B5luver
Dec 18, 2007 12:42 AM
JettaRedII
Oct 10, 2006 01:57 PM
ronin23
Dec 6, 2005 05:03 PM
