Rear Wheel Bearing Tool
well keep trying, the bolt I used worked fine.. and if you can weild and if its grade A it will work.. also just a little helpfull info.. press the bearing on the hub first insead of into the Knuckle, when i did mine I blew up the bearing when i tried to press it into the knuckle first.. make sure it all lines up and your going in straight.. I would use some good grease and grease up the bearing and the hub. and also the inside of the knuckle.. I have read of a few other members messing up the bearing when they tried to press it on..
Kyle_vdk
Jan 11, 2014 10:25 PM
Anybodykilla
May 3, 2006 10:46 PM
