Removing front door panel??
remove the screw in the pull handle, pull out the plastic thing, this will expose two more screws, remove them, remove the screwon the outside edge, in the door jam. now lift up and pull out, to completley get the the thing off the door some other stuff will need to be removed (wiring harnesses, door latch, etc...)
