removing of rear tail light bulb
Old Oct 1, 2005 | 01:04 AM
dudley doright's Avatar
Default removing of rear tail light bulb
Does anyone here have an instruction on how to remove the light bulb for my brake light? I have a 2001 A4 1.8T
Old Oct 1, 2005 | 01:27 AM
BFlan2001's Avatar
Default RE: removing of rear tail light bulb
pop the trunk....there are three caps that you have to pop off (they are covered with the felt material)....once those are off, peel back the trunk liner....you'll see a big clip that holds your bulb harness in place, unclip it and you're good to go....i BELIEVE the brake bulb is second from the bottom, but i might be wrong about that....just look at each bulb and see which one has a broken filament
MagicHobo
Nov 14, 2008 01:37 AM
guitarc
Aug 8, 2008 08:49 AM
10scoach
Jun 12, 2008 10:08 PM
tsk
Apr 27, 2008 04:56 PM
pheonix_625
Oct 10, 2006 12:57 PM
