Reporgramming Key with only ONE key
Ok so I found by searching instruction on how to reprogram the key when you have two of them.
What if I only own one set of key ? Is there a way to reprogram it ?
I have been told that it<s not possible. .....
Thank you
Thank you
RE: Reporgramming Key with only ONE key
Not unless you have a vagcom... trust me I have tried. If you just replaced the batteries then try the way in the owners manual - worked for me once. Other than that, I have yet to succeed reprogramming my one key. I since bought a 2nd one off ebay and will reprogram them soon.
But the instruction I found you needed one key that was already programmed to be able to reprogram it.
I have access to the VAGCOM. If anyone would have a link where I could search VAGCOM instructions that would be great.
Get a blank blade off ebay and get someone to cut it for you. You have to find a place that can drill the pattern, a locksmitting place that does high security systems should be able to.
