Reset everything
Old Oct 26, 2005 | 10:15 PM
dtownhotcorner's Avatar
Default Reset everything
Is there a way to re-set an ECU? i have heard all you have to do is remove one of the battery lines and then plug it back in but i dono if that will work or not
thanks
alex
Old Oct 26, 2005 | 10:23 PM
BadLuckAudi's Avatar
Default RE: Reset everything
In most cars if you unhook the battery for like 15 mins it resets the computers memory but I don’t know if its going to reset everything or what you want it to reset.
Old Oct 26, 2005 | 10:32 PM
ill give it a try thanks man
alex
Old Oct 27, 2005 | 04:56 AM
russianari's Avatar
wont reset any real lights such as airbag or an electonic problem (odometer related, etc.), maybe just maybe it would reset engine light.
Old Oct 27, 2005 | 06:05 AM
sandman's Avatar
yes this resets the CEL, it resets the radio too, hope you have the code.
but if the prob isnt fixed the CEL will come back on.
Old Jan 30, 2006 | 09:52 PM
Slowb5's Avatar
sandman, where is the code at for the radio??
Old Jan 30, 2006 | 09:57 PM
petermcA4's Avatar
What if you just unplugged all the fuses for the ECU and on board diagnostics?
I think there's about fuses 4 in total.
Wouldn't have to worry about re-setting your radio and getting radio codes this way
Old Jan 30, 2006 | 11:10 PM
david9999's Avatar
Why do you feel you need to disconnect your ECU?
If you don't have your radio code, do not disconnect the battery.
Old Jan 30, 2006 | 11:16 PM
p2ii's Avatar
I thought I read somewhere that B6's(I know he has a B5) have the radio coded to the ECU and disconnecting the negative battery terminal wouldn't require entering the code.
Old Jan 31, 2006 | 12:16 PM
sandman's Avatar
ORIGINAL: Slowb5
yea i actually rescently had to disconnect my batterie and when i plugged it back in i didnt need the code.
but........ i think i was just lucky.
the code will be in the manual.
