Rough start / Hard to start after filling with gas
My car runs great, starts great all the time. Then, the first time i start the car after filling with gas, it takes a while to start, and after it's finally started, it idles erratically for a minute or two. It even does it if i fill up with 1/3 tank full (so waiting till it's empty is not the problem).
I have a 2003 1.8t. Has anyone had this problem? |
RE: Rough start / Hard to start after filling with gas
After doing some searching, sounds like it may be the purge control valve? Which may make sense, since I had to disconnect it to replace the air filter. I reconnected it though, but may have screwed something up in the process.
What the heck does the thing do anyways? Is it important that I replace it if it is bad? |
If I remeber right the valve puts vapors from the fuel tank into the intake. It does this during cold starts because the engine needs a richer mix at idle. I would think that if that was bad tho you would get a light on because its an emissions control item
it might have a hard start or be idling rough because the ecu thinks its getting more fuel than it is. that is if thats the problem
i know it sounds stupid... but its your cap on tight ?
my aunt had a problem that her car wouldnt even start because the cap wasnt on all the way |
What's wierd, is I don't have a CEL on, and my gas cap is fine - I can unscrew the gas cap, put it back on, and the car starts fine. Like I said, the car is fine all the time, except for the first time i start it after filling up with gas. Very strange.
thats weird man...what your talking about seems like it has to do with the evap system but 99% of that system is looked at by the ecu. hmmmm.....
sounds like something the dealer ship will charge big money for. or just look at you like your dumb. one or the other. [8D]
ORIGINAL: rccks96 My car runs great, starts great all the time. Then, the first time i start the car after filling with gas, it takes a while to start, and after it's finally started, it idles erratically for a minute or two. It even does it if i fill up with 1/3 tank full (so waiting till it's empty is not the problem). I have a 2003 1.8t. Has anyone had this problem? I will review my old maintenance records when I get home from work this afternoon and repost the remedy and cost. |
Evap purge valve, or the vacuum lines or one way check valve in the vacuum line. Check for leaks or cracks in these, and the 90 degree elbow joints on the passenger side of the engine. Took me a year of leaving my car running when I filled up to finally sort out the problem
