Secondary Air Pump
Ok I looked and looked and I can't find this damn thing.... nor can I find the part number. I keep getting a CEL cuz of it, and it needs to be replaced. Anybody?
RE: Secondary Air Pump
bump for a little help guys
Air-pumps are belt driven in my experience(older cars) so I'm assuming its on the belt circuit somewhere. btw why do you think its the air-pump?
On Audis the secondary air pump is electric. I have mine in the garage, I'll take a look for the part number today.
Some more information on your car other than you have 35% tint would be helpful in providing part numbers and diagnosing problems.
What CEL are you getting that makes you think you need a new air injector? |
yes what are we looking at do you have a 1.8T or 2.8 the pump is located underneath the car on the passenger side all you do is take off the belly pan and it is right there
ah sorry 1.8t 2001. the reason is because i got the fault code for secondary air injector system and ive already replaced a few parts related. let me find the other post i made awhile back
sorry for the lack of help guys |
what is the code # it can really expensive just replacing parts and not fixing your problem
anyways the part # for your air pump is 06A959253B |
https://www.audiforums.com/m_199498/.../tm.htm#199735
the thread that was from b4 and the cel #: P0411 Secondary Air Injection System Incorrect Flow |
yea that is a common one on our cars I had it not long ago myself ended up being my combi valve and the dealer told you to replace the suction jet pump if there is no crack in the l shaped hose and you can blow though the pump that is still fine
goog way to check to see if the air pump is working get someone to turn your car to the on position no start the car but have the accessories on and you get down in front of the car on the passenger side if you here a winning sound your pump is working |
