Service (OIL) Light can't be reset.
Hi,
First time poster around this forum. Any help will be much appreciated. The problem is the following.
After doing the maintenance at a local shop I now want to reset the SERVICE! light. I checked online and I found these two solutions:
1)Turn off the ignition
Press and hold the button on the left side of the display while turning the ignition on
Service OIL will be displayed
Pull out the button on the right side of the display until the service prompt is cleared
The display should now read ---
2)With the ignition off, push the right button
Turn the ignition on and then pull the left button
This should clear the warning message
Now the problem with the first one is that the oil light does not come on for the first solution. Plus my right button cannot be pulled, it can only be pushed. Someone please help.
Thank you
Thank you
RE: Service (OIL) Light can't be reset.
ORIGINAL: audiboy1618
Take a sharpie and color in the oil light.
haha, dude i was just joking.
To add one more thing, I remember reseting once, following those instructions, but now they don't seem to work. Maybe I'm doing something wrong. After pressing the left button, should I let go of it or should I keep it pressed the whole time?
Thank you.
ORIGINAL: Solow
are u sure the care was repaired properly? did audi service your car?
I would also like to add that I thank everyone trying to help.
