shell v-power?
Old May 6, 2007 | 10:38 PM
eurokid's Avatar
Default shell v-power?
is shell v-power bad for the 1.8T engine?
Old May 6, 2007 | 10:44 PM
scotts custom's Avatar
Default RE: shell v-power?
i hope not because i just filled up with that. why would it be bad?
Old May 6, 2007 | 10:53 PM
eurokid's Avatar
idk,, hmm..cause after i put about 5 dollars of it in my car cause i was at the 1/4 line my car started acting stupid, it wouldn't stay on. I made it home but barely, i actually had to roll with my caution lights on a few times cause my car just wouldnt go. Some guy that passed me said it might be that my catalytic converter has a clog and wont let the turbo work...??
Old May 6, 2007 | 10:55 PM
auditech79's Avatar
Sounds like you accidentially pumped in some diesel. Crack open the gas cap and take smell it.
Old May 6, 2007 | 10:58 PM
eurokid's Avatar
gah, maybe..damn those hot chicks at the pump[:@]...what if i did? how do i fix it?
*all i rember is that i used the nozzle on the far right and it had a red top on it.
Old May 6, 2007 | 11:00 PM
auditech79's Avatar
Usually you would drain the tank but since you only put it 5 bucks, i would fill it with gas and use an octane booster as well to balance the octane level.
Old May 6, 2007 | 11:01 PM
Lazer Viking's Avatar
drain your tank. and fill with gas
Old May 6, 2007 | 11:02 PM
eurokid's Avatar
octane booster? and how do i drain the tank if i have to...syphon?
* you may all officially remember me as the idiot who may have accidentally put diesel in his 1.8t...
Old May 6, 2007 | 11:03 PM
auditech79's Avatar
Diesel has a cetane level to measure gas, but if you convert it, it would probably only be about 70 octane which is why it detonates like all hell.
Old May 6, 2007 | 11:04 PM
eurokid's Avatar
"detonates like hell" yeah, that's possibly why my car is having so much trouble gettin pick up right..cause it was hell gettin it to get over 5 mph
*i figured that the gas i put in might have been bad, so i thought i'd try bp which is what i normally use..i put in about $15 dollars of that in...do you think if i just let my car idle for a bit it'd eventually equal out?
