Shiffting at high RPMs!
Old May 22, 2006 | 02:28 PM
techbod's Avatar
Default RE: Shifting at high RPMs!
tiptronic/auto problem but could still need a fluid and filter change or at least have the transmission tested for fault codes
Old May 22, 2006 | 08:37 PM
T_REV_17's Avatar
how much does a tranny fluid and filter change cost?
A) doing it youself
B) taking it in to a shop
Old May 22, 2006 | 08:49 PM
Jovian's Avatar
There is no way of measuring the fluid without a vagcom to my knowledge its more of a shop job. Replacing the fluid should resolve your isssue. It helped my automatic.
Old May 22, 2006 | 11:37 PM
luvin_the_rings's Avatar
ORIGINAL: T_REV_17
it is an auto but here's the thing...Today I tryed using the "manual" 4-speed shifting in my car and it was a lot better than keeping the car in *drive*...now what does this mean?
it means you should buy a 5spd... lol
Old May 22, 2006 | 11:50 PM
flyboy's Avatar
ORIGINAL: luvin_the_rings
ORIGINAL: T_REV_17
[sm=icon_ladiesman.gif]
Its really hard to say without actualy driving your car myself, because what is strange to you might be normal to others and visea versa.
Old May 22, 2006 | 11:59 PM
TheJazz7's Avatar
ORIGINAL: T_REV_17
I'm impressed the thread lasted thing long before someone started hatin' on the tiptronics Keep your head up man!
Get it scanned, and put some new fluid in that bad boy....and keep your fingers crossed, 'cause our trannys are expensive as bawls to fix when they explode.
Old May 25, 2006 | 02:02 PM
T_REV_17's Avatar
yeah very true...I wish I had a 5-speed...but the parents insisted on the auto for my first car lol...sucks for me...and a vagcom is?
Old May 25, 2006 | 03:30 PM
  #18
SilverPullit's Avatar
Vag-com is software that allows you to read different control modules to search for fault codes while also allowing the user to log different sensor readings (i.e. timing, a/f ratio, o2 sensor readings). I have used the software before and it is worth every penny. you are able to download a limited version from the Ross-tech site and you can buy a cable from ebay for cheap.
Kembal
Jan 10, 2013 10:01 AM
Project
Mar 31, 2008 07:54 PM
225tt
Nov 24, 2007 03:00 AM
pat7755
Aug 28, 2007 10:43 AM
Dudek12
Sep 29, 2005 08:00 PM
