snub mount
Old Apr 26, 2006 | 05:05 PM
smokeU's Avatar
Default snub mount
If i'm laying on my back under my car with splash shield removed where should i look to find the and replace the snub mount?
Old Apr 26, 2006 | 05:17 PM
onepoint8tee's Avatar
Default RE: snub mount
front and center... Check APR's snub instructions from their web site or do a search.
Old Apr 26, 2006 | 05:22 PM
north5995's Avatar
You will want to remove your front bumper, and pull the radiator to the "service position". You'll see it better.
Old Apr 26, 2006 | 05:48 PM
No need to put the radiator in service position.. If you take the bumper shocks off and the upper rad. support tabs you can move it forward enough to squeez the snub onto the spindal.
Old Apr 26, 2006 | 06:03 PM
aRIf's Avatar
I need to change mine too...
Old Apr 26, 2006 | 06:05 PM
ORIGINAL: aRIf
sheit man i sold my apr snub, shoulda gave it to you!
Old Apr 26, 2006 | 06:09 PM
aRIf's Avatar
I did not know you had one extra
Old Apr 26, 2006 | 06:18 PM
ORIGINAL: aRIf
yeah i had it on for a while, but the vibrations never went away even after shaving some, so i just got a new oem VW snub.
Old Apr 26, 2006 | 07:44 PM
smokeU's Avatar
I just looked under there and it doesn't look anything like APR's instructions. it seems like the cradle is on the engine and the spindle is welded to the front clip... any ideas? I'm not sure how to get the front bumper off but the apr instructions aren't going to help. I'll go out there and try to get the bumper off... anyone else do this and have that type of setup? any info is appreciated as always. Thanks
Old Apr 26, 2006 | 07:48 PM
Jeff's Avatar
Zombie Defense Force
man y are lots of poeple haveing vibration problems, mine does have more at all
