So is driving on a bad clutch bad or dangerous?
Its pretty much been confirmed...my clutch is gone. I now just want to know if 1. will driving this car on the bad clutch until I can save up enough to buy a stage 2 hurt my car and 2. is it dangerous? Thanks for the help.
RE: So is driving on a bad clutch bad or dangerous?
Yeah it can be dangerous when you driving on the freeway and it just quites on you. THat happened to my friends A4. It started going out over in seattle and we drove it back to Spokane (about 5-6 hours) then it lasted about a week and then it went out while he was on the freeway and almost got hit.
Josh |
ok thanks a lot for the help
Yah it can be bad, especially if it ruins your flywheel and you didnt plan on replacing that.
This is very dangerous because you have to over rev in order for your clutch to catch, this will only kill it faster till it can't grip at all.... I'm pretty sure this isn't nice to your flywheel either, its a hazard while on the road to have a disadvantage like that.
I would say take a loan and goes stage 2 or just get another OEM factory one unless your planning on putting some powerful mods onto it. Be careful man, I've been there done that. It sucks:( |
ok thanks guys. I'm gonna go stage 2 and just have it sit in the driveway until I can get it
ya i found out the hard way when my clutch went out. was at a red light and i went to put it in gear and it was a no go. had about 20 pissed off people behind me. some lady with a cane was yelling at me to move
when its metal grinding on metal (flywheel to used up clutch) it can overheat, cause sparks, make grinding noises and ruin ur flywheel, and possibly transmit shocks and vibrations to your engine and screw something up there... it will usually not get to that point because there simply wont be enough friction to get the clutch down to bare metal... but just not a good idea regardless
yea upgrade it to stage 2 :D
ORIGINAL: Jeff some lady with a cane was yelling at me to move http://warped.org/mopar/pix/swinger-gma2.jpg |
