This sounds like a major transmission repair...any idea?
I can press in the clutch, and run through all the gears. 1-5 ...and even reverse. But....
When I start to release the clutch, all *&% breaks loose. Horrible grinding/clanking noise. I can hear a rotation/spinning going on, but the chunky grinding sound is painful. Any ideas? I'm debating on the Audi dealership or sending it to a certified shop. I ***just bought the thing (small warantee is over, so this is outta pocket). Whole transmission?....clutch?....flywheel? Arguh!! I will repost the results too.... |
RE: This sounds like a major transmission repair...any idea?
This happened to me once. Turned out to be a sheared off input shaft to the tranmission. Obviously the car wouldn't move at all. Can yours?
nope. car does not move at_all. I can still hear the chucky grinding when I push the car (while in neutral).
I just talked to my mechanic, says it 'sounds' like the driveshaft or something along those lines. Getting towed again today over to the shop. Stay tuned. |
Yeah, if if still grinds while in neutral and pushed, I'd say the driveshaft is an issue. That should be less expensive than tranny work. In the interest of saving money, I'd recommend a non-dealer shop as driveshaft repairs are fairly simple. I wish you the best of success.
Is your 2000 not covered under a drive train or bumper to bumper warrenty?
Does your mechanic have experience with Audi Q?
You Nailed it ChrisB. I had it towed to Art Ryan Motorwerks here in St. Pete FL (he is a former Audi/BMW service Manager...and has 65hr rates!). Great guy.
A clutch was installed in the car (only 50k miles. I bought it as a off-corp lease vehicle), and when they installed it they left the driveshaft connections loose. Doh <smacks forhead>! Whew!! Looks like with towing, repair, and parts I am looking at about 3-4 hundred. I really lucked out. So, a clutch is 2g in this car? Wow, that is scary stuff. David_K - no, unfortuinatly the 2000 has a 3yr/50k warrenty. Thanks for the tips. nEil |
