speaker problem.?.?.
i have a 97' a4 1.8t auto... i am having a problem with the speakers in the front... im not sure if they are blown out or what. the speakers in the back work great. but the ones on the 2 front doors just dont seem to work. what do i do to fix this?
thanks for the help...
mike
mike
Step 1: Remove the door panel.*
*IfStep 1 is too hardgo here --> http://www.audiworld.com/tech/int.html
Step 2: Look at speaker connections, if everything looks ok remove speaker and test it with another stereo. If speaker still doesn't work proceed to Step 3
Step 3: Buy new speakers.
Before doing what the above guy said, check your Fader, or whatever it is called... im not too sure on the '97 model, but you could just have to adjust the sound output from the back to both the back and front.... for some reason every now and then my bose system will change to just the back speakers. then i just adjust the **** to balance it back out
