squealing
Hey guys, im getting a high pitched squealing when i take a left turn, and only when i take a left turn, also when i hit a bump i get a real quick squeal, wondering if u guys had an idea, im pretty sure the sound is comin from the driver side front wheel, any feedback would be great, thanks guys
RE: squealing
Is it a squeel like if you hit the breaks and your break pads are low? Or a creak?
RE: squealing
squeal, but the brake pads are fine, and it doesnt even when im not breakin, actually seems to stop when i do, havent heard it too much because i live in mass so havent gotten the chance to have my windows open till recently:D
RE: squealing
woops, sorry bout that last post, just got home i work nites so i must be outta it, anyway...brakepads are fine, i get the squealing when i take left turns, but if i brake while im turning it seems to stop, also i hear it when i hit a bump just like a quick squeal, thinkin somethin came loose, hopin for some help thanks guys
RE: squealing
Check to make sure your wheels arent loose. Check the calipers to see if theyre loose. The shouldnt rock at all. You may have a missing or weak caliper spring.
RE: squealing
def a caliper issue.
