SS install question, help..
Guy no matter what I did I couldn't get these screws out, I was going insane my hands are blistered from twisting the tool.. Is there something I need to know to get these screws out.. And also what size are these nuts cause the bottom one I couldn't even find a socket to fit it..
[IMG]local://upfiles/25696/E66D6C69B32A4ECAA5C2C6D3BD5AC1E3.jpg[/IMG] |
RE: SS install question, help..
Looks like 8 or 10 mm. Try turning it with an open end wrench. My guess is that the whole nut and stud are turning.
wd-40, lol.... if that doesnt work, its like 30 minutes for a shop to install one... so $37.50, thats probably the cheapest thing to sit back and let someone else do the work for you.
u dont have a wrachet...?
go to pep boys and get some penetrating lube... that part's the easiest, the other bolts are in the worst place |
it is a 10 mm and the ones under there are harder to do
yeah when i did mine those came right out easy, i used a socket wrench with the right bit on it forgot the size tho, but small.
