Steering Column Bearings
Old Oct 4, 2004 | 10:50 AM
gary71's Avatar
Default Steering Column Bearings
Has anyone changed the bearings in the steering column on a '97 A4?
Any tips or comments would be appreciated!!
Thanks
Gary
'97 2.8 Q A4
Old Oct 4, 2004 | 02:38 PM
brrman's Avatar
Default RE: Steering Column Bearings
why do you need to change the bearings? What are your symptoms?
Many times people hear a plastic on plastic rubbing noise. This is a result of the spiral spring making contact with the column housing. This is not a detrimental problem and can only be fixed by changing the spring. I have this noise and will probably change it in the spring. (its a big job)
Old Oct 4, 2004 | 02:54 PM
gary71's Avatar
Nope, definitely the bearings. Noise is not the problem, it's free play in the vertical direction. In excess of 5mm at the rim. Audi don't list spares for the column, they say 'service is by replacement only' which will cost more than the car is worth!!
Old Oct 4, 2004 | 02:57 PM
brrman's Avatar
dayum... that sucks man. You always pray its something simple... but the rack is not a cheap replacement.
'oooo'
Apr 11, 2010 10:27 PM
slcrobo
Oct 22, 2009 06:35 PM
Lastb0isct
Feb 17, 2009 03:15 PM
TOMMYTREETRUNK
Aug 22, 2008 05:50 AM
EnviedA6
Jun 6, 2007 07:25 PM
