steering problem...
i notice that when my audi is at stop, the steering get to be really tough to turn and makes sqeaking noise. But when the car is moving, the steering is fine. This happen on and off... anyone know what's going on?
Are our pumps contolled by a belt/pully or electrically...
if it is pump/pulley then at idle/low RPMS the pump may not be pumping enough fluid through... and when you speed up the pressure increases... could be a leak in the pump or a hose
OMG i'm so frickin gald there's a post about this. I've got the same problem and the dealer wanted 250$ to FIND OUT what the problem was.... I told them to hold on while i bent over.
