steering problem...
Old Aug 10, 2005 | 06:04 PM
B5nightrider's Avatar
Default steering problem...
i notice that when my audi is at stop, the steering get to be really tough to turn and makes sqeaking noise. But when the car is moving, the steering is fine. This happen on and off... anyone know what's going on?
Old Aug 10, 2005 | 06:06 PM
clconversion's Avatar
Default RE: steering problem...
sounds like you are low on power steering fluid go to your local dealer and pick up a bottle of G 002000 hydraulic fluid
Old Aug 10, 2005 | 06:13 PM
lilbrownindian's Avatar
i have that same problem but i still have alot of fluid
Old Aug 10, 2005 | 06:26 PM
then you might have a pump that is worn out is it leaking any fluid ?
Old Aug 10, 2005 | 06:28 PM
InsaneHatter's Avatar
Are our pumps contolled by a belt/pully or electrically...
if it is pump/pulley then at idle/low RPMS the pump may not be pumping enough fluid through... and when you speed up the pressure increases... could be a leak in the pump or a hose
Old Aug 10, 2005 | 06:37 PM
sandnsnow24's Avatar
OMG i'm so frickin gald there's a post about this. I've got the same problem and the dealer wanted 250$ to FIND OUT what the problem was.... I told them to hold on while i bent over.
Old Aug 10, 2005 | 07:10 PM
iano's Avatar
i hear a clicking noise as i reverse out of parking spaces. sometimes it's louder than other times. would the tyre size play any part?
Old Aug 11, 2005 | 02:41 PM
nope never seen any fluid
Old Aug 11, 2005 | 02:57 PM
bluovalguy's Avatar
ORIGINAL: iano
Front wheel or quattro?
Old Aug 11, 2005 | 05:29 PM
hoonee46's Avatar
clicking noise could be ball joints, no?
the squeaking could be bushings also...
would you describe it more as a loud whining noise? or 2 balloons rubbing together?
