Stereo problems
Old Jul 7, 2005 | 11:11 AM
stupelfrasse's Avatar
Default Stereo problems
How do I wire to get my stereo to come off with the ignition? The memory (The constant 12v) works but as it's wired now, I have to shut it down and start it manually every time. Can someone please give me a hint how the ISO should be?
Old Jul 8, 2005 | 05:11 AM
MadIce's Avatar
Default RE: Stereo problems
It should be hooked up to a accessory 12v source. Bust out a multi meter and test the wires to find out which one is the acc. and hook it up.
Old Jul 8, 2005 | 12:47 PM
Someone said someting about swapping two cables in the ISO...
Old Jul 8, 2005 | 02:24 PM
brrman's Avatar
if you need a 12 v ignition only source, hook to the 75x power post under the drivers knee bolster
Old Jul 27, 2005 | 08:28 AM
I found the problem.... The owner before me had cut the wire to the ignition...
Paul Davis
Oct 16, 2010 12:50 PM
invisiblewar32
May 28, 2006 01:38 PM
b5 2 8
Mar 16, 2006 02:01 AM
vij31
Feb 16, 2006 07:11 AM
mattd860
Nov 12, 2004 01:52 PM
