Stereo question for 01 A4 1.8t for Kenwood Excelon double din install
Old Oct 13, 2005 | 10:57 PM
diablooffire03's Avatar
Default Stereo question for 01 A4 1.8t for Kenwood Excelon double din install
Where can you get new trim to fill in the space when taking out the stock HU? I have a kenwood excelon double din that needs to be installed and would just like some pointers and to hear the difficulty rating on this, like how the wiring would work out with the stock speakers and all that. It is a 2001 audi A4.
Old Oct 15, 2005 | 01:21 PM
Default RE: Stereo question for 01 A4 1.8t for Kenwood Excelon double din install
Anyone alive here to answer this????
Old Oct 15, 2005 | 01:28 PM
headshok2002's Avatar
more info needed... do you have bose or not?
Old Oct 15, 2005 | 03:16 PM
Yes I do
Old Oct 15, 2005 | 03:49 PM
Fieldy's Avatar
ask your audio shop if they can do it, if you got the spare cash. basically just fashoin a wood board to fit the double din and then fit in your dash, then vynil it, and your done!
here is a pic of mine which is only single din but you get the idea...
Old Oct 18, 2005 | 02:33 AM
I just cant believe they dont sell costum mounts so you can change out the factory double din and not have to worry bout costumizing the **** yurself, jus wish there was somthing that was a perfect fit.
Old Oct 18, 2005 | 01:57 PM
JinCho's Avatar
they might sell a custom mount on metra.com, they probably do. installing a double din radio might be a b*itch, especially wen u have a bose system, having a bose system means that u will have to locate the amp and do an amp bypass. then run new speakers wires to the front of the car and hook it up to ur radio aftermarket radio harness but good luck and if i had to rate how difficult it is, on a scale from 1 to 10 i would say 15
iksnoved25
May 14, 2015 09:41 AM
Emilgevor
Sep 27, 2009 12:06 PM
everfly
Sep 11, 2008 10:44 AM
houseofxenon.com
Jan 21, 2007 03:32 AM
diablooffire03
Oct 13, 2005 08:37 PM
