Sunroof!
Seems to be malfunctioning... could it be the wires? It wont close all the way when opened. I have to do it in intervals.
it wont go from full open to full close, i have to go 25% close 50% close 75% and then full! i wish i can just get rid of it.[:@] |
RE: Sunroof!
is it making any funky noises? it may be a piece of one of the guides broke and is jamming it up...if that's the case you should stop trying to open & close it or you might burn out the motor.
RE: Sunroof!
i had that same problem i replaced the rotary switch and all my problems went away :D
RE: Sunroof!
My rotary switch is a little funny sometimes as well. When I go in for warrenty service, I'm going to tell them it's been acting up... Somtimes I will go from full open to only half closed, after I've moved the dial all the way shut... I feel your pain! [:@]
RE: Sunroof!
ORIGINAL: KarlMarx My rotary switch is a little funny sometimes as well. When I go in for warrenty service, I'm going to tell them it's been acting up... Somtimes I will go from full open to only half closed, after I've moved the dial all the way shut... I feel your pain! [:@] ahh its so annyoing! |
RE: Sunroof!
If the rotary switch isn't the problem, bring it in and check if there's a dirty or faulty wire connection. My sunroof would sometimes open by itself and close.
RE: Sunroof!
Mine will not close all the way sometimes, if you twist it around to the pop up mode it will usually close it though. I have wondered on how to fix it... probably the switch huh?
RE: Sunroof!
Mine completely is out of whack ill open it and it wont come back to close ill have to literally grab it and pull it back to place. Ghetto as hell i just forget that i have a sunroof cause the guy i took it to quoted me 600 bucks to fix.... Pass.
RE: Sunroof!
mine would open and close when ever it wanted, sometimes wouldn't open or close, replaced the switch and no more probs.
RE: Sunroof!
Mine sometime does not close from full open to close. I have to go in intervals. I dont know what it it, but seems like electronic issue, I checked mechanical parts no problem there.
