Sunroof sticking
I was wondering if there is any way to oil or grease to sunroof tracks, or any other way to fix it, when i open my sunroof the further it goes back the harder it is for it to open, it kind of studders when opening, plus it is kind of slow. I dont think it is the clips you can get from ecs because it still opens and closes fully, but it is just kindof annoying. Thanks for any help.
RE: Sunroof sticking
you can grease your tracks, I do mine about once a year, don't put to much you son't want globs of grease falling off where you can't get it.
Silicone spray lubricant stays clean.
i had the same problem. greased it... it went away.
actually...mine sometimes makes the sound of plastic snapping when i just chage the
switch to the sunroof lifting a bit (not sliding off)...i couldn't figure out why it's doing that...almost like some plastic in there was about to break while opening and closing... what do u think's up with taht? |
Well I sprayed a heavy coat of silicone on the track and i tried to get back as far as i could, but it seems like it made it worse, and now it gets stuck and stops before it opens completely. I think i am going to try and grease the tracks, but what kind of grease should i use? When i was spraying the silicone i noticed that there was already grease on the tracks, and it was yellowish in color.
White LITHIUM grease.. do not buy a petroleum based grease as it can eat away at plastics, I had the same problem, and I just tried mine.. working good.. (I greased it like a few months ago, but I havent opened it due to fear/winter)
be sure to clean all old grease off as some do not mix at all and will turn to a hard wax like craaap
Ok thanks i will try that, hopefully it works.
