Temp regulator flap problem..cold air
Old Nov 27, 2005 | 07:33 PM
gregp1962's Avatar
Default Temp regulator flap problem..cold air
My heater blows out cold air. The heater core is circulating water and both hoses are hot. The thermostat is ok. The engine temp gets warm fast enough.
When I search codes at http://www.audiworld.com/tech/int5.shtml#DiagCodes I get a 22.1 as the first system malfunction code which makes no sense as that is talking about the a/c.
Does anyone know how to manually open or close the flap? Also, does anyone know what would be appropriate values for codes 36 to 37 on that chart?
Old Nov 28, 2005 | 03:49 AM
mastvadz71's Avatar
Member
Default RE: Temp regulator flap problem..cold air
go to basic setings
1 enter addres word 08
2enter basic setings 04
3group 000
befor enything remove glovecompartment than do basic setings and observ center flap motor movement and readings
and if it does not mach number an movement replace center flap motor or disconect from rod and closet manualy
Old Nov 28, 2005 | 08:25 PM
gregp1962's Avatar
mast,
What does that all mean? Can the center flap be seen when the glove compartment is removed?
Old Nov 29, 2005 | 10:15 PM
mdeerfield's Avatar
Since my 1998 is currently in the shop for (among other things) this same problem - I'd also be interested in what your learned. It looks like my problem is related to the lap also as both sides of the core are warm. I actually faxed the dealer this post (I'm sure they'll be thrilled) since they are talking about dismantling the center console to get at it.
Old Nov 29, 2005 | 10:19 PM
mastvadz71's Avatar
Member
yes when you remove the glove box you will see 3 motors atached to the evap box.the one in the middle is the one you need to check and work on
Old Nov 29, 2005 | 10:21 PM
mastvadz71's Avatar
Member
i am not saying i'm the best but yes it is almost true .i have been working for audi dealer for 7 years and i know your pain.now i am on my own with my own place and i am helping a lot of people from geting riped off in the dealer.
Old Nov 30, 2005 | 08:01 AM
gregp1962's Avatar
Mast, your answer brings another question. I also need to replace the evaporator core. Does the whole dash have to come out to do that? Is it hard to get the glove box out?
Old Dec 1, 2005 | 08:28 PM
gregp1962's Avatar
OK, I took out the glove box. There are not any motors or anything that look like controllers behind the glove box. Are you sure you mean the glove box?
Old Dec 16, 2005 | 04:48 PM
gregp1962's Avatar
I think I found them! Behind the radio and climate control unit, there are some black plastic things with some red and some blue plastic things on them. Are those the actuators?
I didn't have to remove anything to see them. But, I had to lay on the passenger side floor, looking up towrads the middle of the car.
gregp1962
Sep 24, 2020 09:11 PM
ericcota2003
Dec 2, 2010 11:18 AM
jankerfun
Nov 12, 2007 01:47 PM
neilechols
Nov 30, 2006 02:52 AM
gregp1962
Dec 16, 2005 08:05 PM
