Temperature decrease
Your coolant temp gauge or your oil temp gauge?
If coolant, it should be right in the middle when warmed up.
Oil temp should be 250ishat most in summer and 200-225 in winter, and will take longer to warm up.
What oil are you running? And I don't think oil can affect your coolant temp... actually it might, would it get hotter if the oil was not lubricating well enough or if the oil is cooler than normal it will decrease engine temps? I could see that helping with that. What are your oil temps? I'm not sure about this.
Josh
Josh
