Tie Rod Replacement
Old Nov 1, 2005 | 07:59 PM
seohkim's Avatar
Default Tie Rod Replacement
I replaced my front tie rods and it seems to be worst than before. Whenever I hit bumps my Steering wheel jerks and it seems as if I lose control of my car. And the ride of my car is alot harder I feel every bump. Before I replaced the tie rods I had a smooth ride.
Any one know if this is normal or what should be done?
Old Nov 1, 2005 | 08:03 PM
sandman's Avatar
Default RE: Tie Rod Replacement
did you get it aligned?
maybe it was the control arms that were jacked instead of the tie rod ends or a combo of both.
Old Nov 6, 2005 | 04:42 AM
dankhound's Avatar
Sounds like whoever replaced your tie rods skimped on the alignment. There is an adjustment on audis that most cars dont have. Its called raised toe. This adjustment is there to eliminate bump steer, which is what you described.
mokey40
B7 Models
Nov 28, 2014 12:42 PM
mtnxtreme
Audi Q7
Dec 16, 2013 01:11 PM
matthayzon89
Jul 31, 2013 10:51 PM
hankeester
Jun 24, 2009 12:10 PM
