timing belt
im right at about 70k and i was wondering if it was about that time to get my belt replaced....if not now, when is a good time?
RE: timing belt
Yep deff a good time to do it, you dont want to push something like a t belt if it goes it will most likely take the rest of the motor with it so its better to be safe than sorry
RE: timing belt
yeah the cost of repair will be crazy...i want to do it soon!
RE: timing belt
whats the cost for getting the belt changed? roughly... i know the belt itself isn't expensive but the labor to put it on is ganna run me? my odo is at 95k so i have to call the last owner and see if it was changed and if not i guess i def need to do that
RE: timing belt
anywhere from $700 to $1000 to get it replaced, depending on where you go...
(timing belt) |
RE: timing belt
do it now, u will see some guys just broke at 62xxx so imo now
RE: timing belt
3-500 for labor You also need to change all the associated parts including tensionwer, idler. Should do front engine seals and water pump at same time.
