tire wear --when to replace
Ive got an 03 A4 with 17" tires and 36k on it. When i was getting serviced for a fuel pump that died, they said my tires were pretty worn and i should put new ones on. I dont do any hard driving, so i think these should be lasting longer.
Anyone out there with an idea of how many miles the 17" tires should go these days before they should need to be replaced?
Look for wear bars
These are narrow bands that appear in the grooves across the tread of the tire. When the wear bars are even with the tread depth, only 2/32-inch of tread remains. If you can see the wear bars, it's time to replace the tire.
- The Penny Trick
The other way to tell if the tread is worn out is to place a penny into the shallowest tread groove with Lincoln's head down. If the top of his head remains visible, then the tire should be replaced.
- The Penny Trick
sirfalconx
Nov 22, 2007 09:27 AM
