tire wear --when to replace
Old Mar 24, 2006 | 06:06 PM
apf232's Avatar
Default tire wear --when to replace
Ive got an 03 A4 with 17" tires and 36k on it. When i was getting serviced for a fuel pump that died, they said my tires were pretty worn and i should put new ones on. I dont do any hard driving, so i think these should be lasting longer.
Anyone out there with an idea of how many miles the 17" tires should go these days before they should need to be replaced?
Old Mar 25, 2006 | 01:37 PM
david9999's Avatar
Default RE: tire wear --when to replace
Depends on the type of tires and whether you have an alignment problem, under inflated your tires, or decided to burn rubber.
36K isn't an unreasonable distance
Old Mar 25, 2006 | 02:58 PM
headshok2002's Avatar
You have the dunlop 9090's or the Continentals? Both of those tires wear quickly... the continentals wearing more quickly than the dunlops.
Old Mar 25, 2006 | 03:02 PM
Jestnomen's Avatar
6th Gear
Look for wear bars
These are narrow bands that appear in the grooves across the tread of the tire. When the wear bars are even with the tread depth, only 2/32-inch of tread remains. If you can see the wear bars, it's time to replace the tire.
- The Penny Trick
The other way to tell if the tread is worn out is to place a penny into the shallowest tread groove with Lincoln's head down. If the top of his head remains visible, then the tire should be replaced.
adioman6000
Nov 9, 2010 10:57 PM
fireman9585
May 19, 2010 08:25 AM
duke7487
Oct 1, 2009 02:38 PM
sirfalconx
Nov 22, 2007 09:27 AM
seaurchin99
May 26, 2005 11:39 PM
