torque specs
Component
Tightening torques
Oil return line to turbocharger
10 Nm (7 ft lb)
Turbocharger bracket to turbocharger ( bolt and washer assembly M8)1)
40 Nm (30 ft lb)
Turbocharger bracket to cylinder block
45 Nm (33 ft lb)
Oil feed line to turbocharger
25 Nm (18 ft lb)
Coolant supply pipe bracket to turbocharger
10 Nm (7 ft lb)
Oil supply line bracket to cylinder head
20 Nm (15 ft lb)
Coolant supply line to turbocharger
25 Nm (18 ft lb)
Crankcase ventilation line to cylinder head
10 Nm (7 ft lb)
Coolant return line to turbocharger
30 Nm (22 ft lb)
Turbocharger to exhaust manifold
35 Nm (26 ft lb)
Three Way Catalytic Converter (TWC) to turbocharger
30 Nm (22 ft lb)
1) Bolt strength: 10.9
Tightening torques
10 Nm (7 ft lb)
40 Nm (30 ft lb)
45 Nm (33 ft lb)
25 Nm (18 ft lb)
10 Nm (7 ft lb)
20 Nm (15 ft lb)
25 Nm (18 ft lb)
10 Nm (7 ft lb)
30 Nm (22 ft lb)
35 Nm (26 ft lb)
30 Nm (22 ft lb)
