Sponsored by:
Sponsored by:
totally amazing!!!
Old 07-13-2005, 09:52 PM
iano's Avatar
Default totally amazing!!!
you are obviously curious about what is so toally amazing. well let me explain. i explained the problems with my front suspension last saturday. to re cap- the front left suspension has gone up by half an inch. it has had some new parts, all were correct and fitted correctly. it has had two new shocks in the back. however no one can give me a logical diagnosis. today i decided to get out my tape measure and discovered that the front left is up by 15mm. not only that, but the wheel also appears to be 10mm more forward than the right hand side wheel using the moulding on the wing as the fixed point. i can't measure it but i am convinced that the wheel seems to be more cambered than the right side. it's fairly obvious to see when you know to look for it. what's amazing about that. well....nothing but i bet you would have overlooked this message if it was entitled "dull suspension problem". however it does shed new light on the problem and leads me to a more simple question- what can bend in the suspension that would lead to the wheel being so far out of line.( please forgive the lay man's terms)
Old 07-14-2005, 12:09 AM
Shaunp05's Avatar
Default RE: totally amazing!!!
Ok wat you trying to say is the wheel has exccesive Caster....
Caster is when the wheel tilts foward or backwards
Camber is whn it tilts inward towards the car or away from the car
to answer your question alot has to bend for that to happin
both upper controll arms
More so if you dislocated the Subframe ????
Old 07-14-2005, 12:31 AM
headshok2002's Avatar
go get an allignment...
larandbec
08-29-2011 09:52 PM
techbod
01-09-2008 03:10 PM
coloradoA8
02-28-2006 03:55 AM
iano
07-25-2005 02:15 PM
iano
07-18-2005 08:23 PM
Quick Reply: totally amazing!!!
