Transmission problem...
so my car has been in a pretty shitty mood lately...now the problem is that the transmission is over revving. Under normal/harder driving conditions, after the 1sdst three grears, i shift into fourth and get on the gas and sometimes the engine revs from about 2500 all the way to 4500k without the car really accelerating...then comes the lovely burt clutch smell.....thoughts? do i need new trans. fluid? gah i hate this car.
--E |
RE: Transmission problem...
You might want to check your brake fluid levels, because that's what the clutch draws from.
so some brake fluid may solve my problem....any reccomended brand/type...thanks
--E |
Dot 5 fluid, and I think it's all the same stuff, brand wise
o my goodness... lol tranny fluid will not solve your problem.
your clutch is slipping, which means its on its way out. I hate to break the news but its time for a new clutch, trust me I know what im talking about also, theyre is absolutely no other possible problem, its your clutch. 100% positive. go to ebay and find a cheap oem clutch, or if you wanna upgrade theres so many out there, it just depends on the type of power you want it to hold. |
oh god dammit, i hate this car....thanks...
--E |
what exactly do i need...clutch, pressure plate etc? any help is appreciated..
--E |
ORIGINAL: AteUrV8 o my goodness... lol tranny fluid will not solve your problem. your clutch is slipping, which means its on its way out. I hate to break the news but its time for a new clutch, trust me I know what im talking about also, theyre is absolutely no other possible problem, its your clutch. 100% positive. go to ebay and find a cheap oem clutch, or if you wanna upgrade theres so many out there, it just depends on the type of power you want it to hold. Do you want to go stage 2 or buy another stock clutch.. that is the question |
Sounds like time for a new clutch. Do not put DOT 5 in the brakes. I believe that it takes Dot 4(+), at least B5s do. Dot 5 is not compatable.
DOT 5 is silicone.
