trouble shooting on bearing change
i read the write up from audiworld, on the rear bearing job. And it was simple. Until the arm wont come off the bolt after all the nuts are off.....any tips???i've been workin on it for 2 na half hrs............no luck :[ these are pics from the site. My arm is still in tack with that bolt.
sucks bad! i finally gave up trying to bust apart my front end when i replaced shocks/springs. i had to give it to my mechanic to bust it all apart since it was rusted together so badly after 90k+ miles.
I am sure you have figured this out by now, but incase you are still pondering it... you need a ball joint remover tool. When I was just learning my skills of repairing car I use to use everything imaginable to get those kind of things apart, usually for hours. Then when I grew up I figured out that with the right tool I could spend a lot more time driving and had a lot less injuries. Hope you got this figured out and didn't have to take it to the stealership.
