Turbo cooling issues. Where is the hot spot?
Old Dec 27, 2006 | 10:56 PM
gregp1962's Avatar
Default Turbo cooling issues. Where is the hot spot?
I don't have a turbo timer. I'm not patient enough to sit in the car for a few minutes before turning the engine off. Does it make difference if I make sure that the engine is not under a load the last few miles of driving? Isn't it true that if the engine isn't under load, the turbo isn't working at all and the coolant is still flowing and cooling it off? If so, it is probably a good idea to run above idle while cooling off in the driveway.
I'm alsowondering what part is the crucial spot for coking of the oil. It is inside the turbo housing, or inside the oil line that runs over the turbo?
Old Dec 28, 2006 | 12:19 AM
AudiCross's Avatar
Default RE: Turbo cooling issues. Where is the hot spot?
okay. first ist not coolant, its oil running through it. and secondly, just for the last 5 minutes, be gentle. if its not in the boost, then ur not pressurizing air, then the air deosnt get hot meaning the turbo gets cold. even if ur a little in teh boost, it wont hurt it. just be gently the last few minutes. nad big sign ur turbo is too hot is when it looks like a lightbulb. thats bad. as in bad bad. as in dont-turn-it-off bad...
Old Dec 28, 2006 | 02:34 AM
sean1.8t's Avatar
^^its actually oil and coolant running through the turbo
but he is right about one thing, just stay off of boost for the last bit of your drive and your turbo will really appreciate it.. if you are on the go a lot like me then a turbo timer is a cheap and nice feature to have. less than a hundred bucks and super easy to install
Old Dec 28, 2006 | 02:41 AM
luvin_the_rings's Avatar
as long as you chill for the last coule miles ur good
oil and coolent run through the turbo
i would kno as i just got soaked in both...
Old Dec 28, 2006 | 04:02 AM
Cruiserhead's Avatar
what rpms does the turbo boost kick in?
Is driving 3K rpms considered easy? 3.5K? 4K?
thanks guys
Old Dec 28, 2006 | 04:37 PM
SAudi's Avatar
if your impatient just get a turbo timer their really not that expensive.
Old Dec 28, 2006 | 04:38 PM
B6er's Avatar
It can kick in as early as 1950 rpms from my experience. It really matters how much throttle you are giving it.
Old Dec 28, 2006 | 04:43 PM
new2me's Avatar
According to my boost guage I can go up to 5k without boosting if im easy on thegas.
vitamins
Mar 18, 2015 06:36 PM
SubaruHyundaiAudi
Jul 24, 2013 11:28 PM
ssbike
Apr 9, 2009 12:15 AM
naid
Aug 21, 2006 12:11 PM
AMeicher
Nov 17, 2004 04:14 AM
