which turbo on my a4?
Old Jan 5, 2006 | 05:59 AM
FASTER's Avatar
Tech Slut
Default which turbo on my a4?
i have a black 99 a4 1.8t avant quattro 5spd, with the blown stock turbo, blown cat and blown clutch i now need all three, im leaning toward the gt28rs kit from atpturbo.com n a high performance clutch from them as well. any thoughts on that? would any of you go a diff route? the gt28rs kit
Old Jan 5, 2006 | 06:25 AM
Jeff's Avatar
Zombie Defense Force
Default RE: which turbo on my a4?
imo get the stage 3+ set up from apr and a spec stage 3+ clutch with lwfw u wont be disapointed
Old Jan 5, 2006 | 07:02 AM
18T's Avatar
18T
apr stage 3+ with ECS stage 2 or 3 clutch
Old Jan 5, 2006 | 02:53 PM
InsaneHatter's Avatar
How good are you mechanically?
IF you can work on cars I would peice together a t3/4 Turbo kit. bitterchild over on the zine could prolly set you up with something.
You will need a manifold,turbo,dp,all coolant/oil/whatever lines, software, injectors, MBC .. and more. and get a Southbend DXD clutch... it will be nice...
I think bitterchild may be able to tune seomthing for you as well...
let me know !
Old Jan 5, 2006 | 03:04 PM
TomRitt's Avatar
ORIGINAL: InsaneHatter
Thats what it comes down to. if you arent that great a fabrication and what not go apr stg3+ otherwise u can piece together ur own kit and make more power
Old Jan 5, 2006 | 04:13 PM
clconversion's Avatar
OMG did you do thi all at once ?
Old Jan 5, 2006 | 04:18 PM
FASTER's Avatar
Tech Slut
thanks guys but im not donald trump and dont have an extra 5 and a half grand. that kit has been in my eye for quite awhile i jus cant spend that kid of money. im looking more to spend like 3.5 to 4 grand including the clutch and any other needed componenets. wat about now? and if ur asking can use a wrench, the turbo work is no problem, obviously i cant tune the ecu tho. ps i already have apr 93 octane chip, milltek turboback exhuast, hyperboost dv, and an evo cold air.
Old Jan 5, 2006 | 04:23 PM
FASTER's Avatar
Tech Slut
some jackass put 108 leaded in her wen he was supposed to put vp104 the cat blew causing the turbo to blow. n the clutch story is just plain embarrassing.
Old Jan 5, 2006 | 04:26 PM
onepoint8tee's Avatar
ORIGINAL: FasterA4ThanUrs
5 and a half g's is chump change to Donald Trump... Why dont you get a loan
Old Jan 5, 2006 | 04:28 PM
o man that sucks come on we have herad some bad storys here I will tell you how I blew mine as soon as we installed my BT system we took it for a test drive and as soon as I put it in second it wouldn't hold any more
