tweaking a KO4
Old Jan 30, 2007 | 01:35 PM
MissionCtrl's Avatar
Default tweaking a KO4
Just a quick question.
Where I work they rebuild turbo's, so...since I have a brand new KO4 in my trunk, I was wondering if there was anything I could do to it to get a bit more power out of it and still be able to run the PC-16 file with it? I posted this in general tech but didn't get much for hits, thought I'd try here. I want to p&p, ceramic coat, clip, and whatnot, but will my computer be able to compensate for the increased flo?
Old Jan 30, 2007 | 01:53 PM
JohnnyBravoA4's Avatar
Default RE: tweaking a KO4
I dont think you can do much, you can take it apart and have the housing coated, that makes them flow a tad better and keeps the heat down..other than that i dont know..
Old Jan 30, 2007 | 03:20 PM
hmmm, maybe i should must p&p the mani instead...think i'd get better gains from a p&p on my mani?
Old Jan 30, 2007 | 03:45 PM
you can give it a shot, if you have the tools or can get it done cheep also install a test pipe.. get better spooli noticed a huge difference with my ko4 in my old car after a test pipe..
Old Jan 30, 2007 | 03:56 PM
yeah definitely slappin on a test pipe when the turbo gets thrown on, also will be putting on custom 2.5" exhaust and fabbin up a CAI
Old Jan 30, 2007 | 04:00 PM
sounds like what I did.. I used a magnaflow muffler sounded sweet.. 2.5inch is good, I think anything more with a test pipe would flow to much.. you need a little back presure.. with my set up i would chirp all 4 tires when the turbo spooled it was nice..
Old Jan 30, 2007 | 04:05 PM
Yeah im using a magnaflow muffler too, I hope it sounds good. Im not going to have a resenator for a while, see how it sounds and go from there.
Old Jan 30, 2007 | 04:21 PM
its definatly loud.. trust me.. louder then a borla set up, and it tends to drone a bit on the highway.. you will want a resinator after a few weeks
Old Jan 30, 2007 | 04:40 PM
I can live with a little drone....hopefully the exhaust note and engine sound will cancel each other out lol. I'm sadly used to ricer drone so this shouldn't be too bad.
Old Jan 30, 2007 | 05:12 PM
ha..you will like it then..
