Vacuum Pressure
96 V6Engine 12valve
Vacc Pressure 18-20 Vs 99.5 A4 1.8T Vacc Pressure 10-11 Ok, I got rid of my old A4 but I had vaccumm pressure gauge installed. Iwas 18-20 On my new car 1.8T 99.5 it's 10-11 Is that correct? Why do i have a feeling it should be 16-19 at least. |
RE: Vacuum Pressure
it should be between 18-21
RE: Vacuum Pressure
Sounds like a leaky. Should be around 20 for sure.
RE: Vacuum Pressure
You got a leak.
RE: Vacuum Pressure
Vacuum is opposite pressure. Vacuum pressure is an oxymoron. Pressure is usually measured in Lb/sq.in. , and vacuum in inches of Hg.
RE: Vacuum Pressure
Mine sits at 18-20 Hg at idle...u gots a leak.
RE: Vacuum Pressure
its a leak!
RE: Vacuum Pressure
Problem fixed!
