vag-com results
hey guys just ran the vag-com on my car. i have 2 files, im not sure how to read them so maybe if you not busy you guys can take a look. ones a text doc with codes and the other is excel file. just let me know if i have anything wrong with my car. thanks
[IMG]local://upfiles/21842/10EBEF21963A4DEE8924AC2006632D39.jpg[/IMG] |
RE: vag-com results
Zone Alarm sucks and Dameon Tools is cool. You using the new IE 7?
Those numbers look ok to me.. The best way to test though is to start recording the blocks, put it in 3rd or 4th and go WOT to redline from about 2k rpms and then stop recording. |
RE: vag-com results
it it better if you log 002,022, and 031 I believe... so you can see the timign and all that crap that you w'll need. also I think it is either 1st or 2nd gear pull. try it like onepoint8tee says, 3rd gear wot from 3k to redline.
RE: vag-com results
i have a automatic with tip, is there a certain way to do it with the tip? and yea, uts IE7
RE: vag-com results
