VAG TOOL ?
Old Sep 7, 2006 | 06:13 PM
active1331's Avatar
Default VAG TOOL ?
can someone give me a quick run down on what this thing is all about and will Rosstech work with my car being chipped
Old Sep 7, 2006 | 06:20 PM
SilverPullit's Avatar
Default RE: VAG TOOL ?
Vagcom allows you to plug a laptop/computer into the OBDII port on your car and read differenet control modules (ECU, TCU, Comfort control, headlights etc). this is very useful as you upgrade components on your car because you can monitor A/F, Cylinder status, and graph different points of interest. although VAGCOM is expensive it is worth it.
you can also do mods with it (remote window mod, running light mod, clear CEL's )
Old Sep 7, 2006 | 06:23 PM
chuckievi's Avatar
It also lets you check/clear check engine lights
Old Sep 7, 2006 | 06:24 PM
active1331's Avatar
where is the best place to buy one?
Old Sep 7, 2006 | 06:38 PM
really the only place is http://www.ross-tech.com/
Old Sep 7, 2006 | 06:40 PM
chuckievi's Avatar
thats if you want an official one, you can buy the cheap cable off of e-bay and download the shareware version of the software to get minimal functionality.
Old Sep 7, 2006 | 06:43 PM
if you buy a cheap on off ebay... do your research because you may end up buying one that will not work properly with your car especially if you have Xenon Headlights (and a few other select modules that are on a different bus) and want to talk to that module.
bshusted
Jul 31, 2013 08:46 PM
desertsnake1991
Dec 11, 2012 07:00 PM
ericcota2003
Apr 2, 2010 10:44 AM
S1lenz
Jun 1, 2009 12:03 AM
rvtech1835
May 5, 2004 06:55 PM
