VAG TOOL ?
Vagcom allows you to plug a laptop/computer into the OBDII port on your car and read differenet control modules (ECU, TCU, Comfort control, headlights etc). this is very useful as you upgrade components on your car because you can monitor A/F, Cylinder status, and graph different points of interest. although VAGCOM is expensive it is worth it.
you can also do mods with it (remote window mod, running light mod, clear CEL's )
if you buy a cheap on off ebay... do your research because you may end up buying one that will not work properly with your car especially if you have Xenon Headlights (and a few other select modules that are on a different bus) and want to talk to that module.
desertsnake1991
Dec 11, 2012 07:00 PM
