vvme hid installation question ..
Old Jun 29, 2007 | 11:49 PM
onebelo's Avatar
Member
Default vvme hid installation question ..
quick question regarding installing the kit .. i have a 2000 B5 and do you have to remove the headlights from the car to install it?? planning on getting the 6K kit. tx =)
Old Jun 30, 2007 | 12:02 AM
Belligerenceâ„¢'s Avatar
Default RE: vvme hid installation question ..
no.
Old Jun 30, 2007 | 12:04 AM
onebelo's Avatar
Member
simple enough. thanks
i saw a post on AW that the guy did so, so i was just wondering.
Old Jun 30, 2007 | 12:10 AM
no problem.
I'm sure it'd be easier to install them with the headlights out, but it isn't overly difficult with them in place either. the only thing you'll have to pull out of the car (other than the existing headlight bulbs, obviously) is the plastic dust caps which cover the hole in the back of the light that the bulb goes into. you'll have to remove these dust caps so that you can drill a bigass hole in them to run the wires for the HID bulb through the cap.
Old Jun 30, 2007 | 12:16 AM
onebelo's Avatar
Member
oh ok. yea one of my dust cap for some reason was missing .. so i got one from the dealer but never got around to puttin it on cause one of the clips is stuck somehow and i think in order to get it out, i have to take that one headlight out.
where did you end up placing the ballast?
Old Jun 30, 2007 | 12:27 AM
Trey25's Avatar
Most people put it under the headlight, which means you'll have to remove the headlight. I don't see whats the big deal about, its only 3 torx screws.
Old Jun 30, 2007 | 12:40 AM
onebelo's Avatar
Member
yea the 2 screws is easy just that one really deep one is harder to get to unless you have the right tool .. which i would need
Old Jun 30, 2007 | 11:16 AM
CRAZYHAWK's Avatar
You'll need a 1/4" six inch extention and a 1/4" T-30 bit to remove thre rear screw.
Old Jun 30, 2007 | 11:48 AM
JETSPEED333's Avatar
SoCal Crew Member
personally I'd take the headlamps off the vehicle so i could mount the ballast on the bottom.... i believe on your car there is an indention for the ballast....and Velcro works great to mount them
p.s. buy the tools necessary to work on your car!
shortyxc
Jul 13, 2009 11:41 AM
trevor51590
Jan 6, 2008 07:10 PM
viper9821
Sep 30, 2007 10:02 AM
itsnumb
Jun 11, 2007 12:00 PM
ImTheDevil
May 14, 2007 05:19 AM
