w/m injection`
Old Jan 4, 2008 | 12:11 AM
Mya4T's Avatar
Default w/m injection`
alright so as a couple might know. i have another audi on the way. 01 a4 with a test pipe 2.5 inch exhaust fmic and stage 2 revo chip. i asked in another post about putting a ko4 on with the revo chip. cincy said that w/m would be the best w ay to go and i would get better results with that then a ko4. i did some research on the w/m and i can see why that owuld be a good idea. while searching i was looking at all the different tunes and ways blah blah blah. just wanted to know where would be the best place to get a water meth injection what tune. basically what i need to do from scratch and all that good stuff. around how much it would cost to. could it be installed myself or better to get it installed professionally? let me know thanks for the help!!
Old Jan 4, 2008 | 12:20 AM
Karl's Avatar
Default RE: w/m injection`
Call Scott @ USRT (Usually Sideways Rally Team)
Old Jan 4, 2008 | 12:21 AM
chaos92287's Avatar
no tuning needed. you can install it yourself
http://www.snowperformance.net/product.php?pk=58
are you sure revo has stage 2 software for a b5? i thought that was just for the b6...
Old Jan 4, 2008 | 12:24 AM
Mya4T's Avatar
revo doesnt do it by b5 b6 b7 they just have the different 1.8 engines. they have the four different motors with the stock bhp so yea they have it
Old Jan 4, 2008 | 12:27 AM
chaos92287's Avatar
if you say so
Old Jan 4, 2008 | 12:38 AM
EVOLA4's Avatar
+1 check out snow performance. I have been looking into it myself. I want to either do that or maybe a e85 set up. due to gas prices and more hp!
Old Jan 4, 2008 | 01:35 AM
cincyTT's Avatar
I'm make believe
either get a snow or devils own kit, both should be a stg2 kit with a progressive controller. If you want the best performance out of it you should look into a dual nozzle kit. As for tuning, you can either do it with lemmiwinks or just run a 100octane chip. I rather lemmi it personally since you should be watching knock.
The install isnt to bad and if you can wire, you can do it yourself.
As for EVOLA4, you dont need to mod anything for e85, just keep it under 50% mix.
Old Jan 4, 2008 | 05:39 PM
Mya4T's Avatar
who do i talk to about tunning or where can it be done?
Old Jan 4, 2008 | 06:24 PM
cincyTT's Avatar
I'm make believe
get a vagcom cable and download unisettings. Then go run logs andincrease timing via uni until you pull no more than 3-5* of timing. Then back it down to 0* of pull and you are done. If you want more help, this topic is discussed alot in the 1.8t section on vortex
Old Jan 4, 2008 | 11:07 PM
chaos92287's Avatar
ORIGINAL: cincyTT
i thought you couldn't adjust timing w/ unisettings or lemmiwinks on an aeb
